Summary of the issue:
After upgrading to the latest version of OS on my iPad, Automix runs into issues when the screen turns off. It will start looping the current song playing or the volume will cut off and high pitched sounds will occur.
Once you turn the screen back on and select the next song in the mix it stops but only if the screen stays on. This did not happen before, and does not happen on my iMac or iPhone.
Please advise if this issue will be fixed.
Hi @SC2200, thanks for the details about your setup and the issue. I was not able to replicate this. Can you please try to capture a short video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
I’m using my locally stored Itunes music. I also tried wiping the device completely, reinstalling the OS and Djay app but the problem was still there.
I have the same music/playlists on my Iphone and IMac with no issues? All I can think of is there is a bug with the new OS version for IPad and Djay Pro?
Thanks for the additional info @SC2200. I haven’t been able to replicate this so I need to pass it onto our engineering team for further review. I’ll report back when I have more news. Thanks!
Are there any updates on this issue?
I’ve confirmed that this is also happening when streaming music or just playing any song on either deck. Once the iPad screen turns off the issue occurs.
Hi @SC2200, unfortunately, our engineering team has still not been able to replicate this issue on their end. Are there any other things you can think of that might be contributing to the issue that could help us replicate it?
I had some time to look into this issue further and may have found out the cause but no solution.
I narrowed it down to the Neural Mix transition option in Automix on my iPad. Both my Iphone and Imac do not have the Neural Mix for transition option which is probably why I have no issues on those devices.
I normally have Automatic selected in Automix and when it uses the Neural Mix to transition songs thats when I get those issues. Once I switch it to any of the other transitions, Filter, Fade, Riser etc. no issues occur.
Its very strange, as this used to work before on my iPad, again all I can think of is there is a bug with the latest version of IOS?
Please let me know if this helps in any way to get a solution to this problem. I should be able to use Neural Mix option for transitioning songs in Automix, like I did before.
Hi, I have exact Same issue. My specs are similar - IPad Pro 11.1 2nd Generation IpadOs 18.2 Djay Pro 5.2.8
To reproduce the issue you just need to start Automix from any Streaming Service and Turn off Display. After a couple of minutes you will experience high pitch Sound or Strange Loop. On Bestport it comes very fast, on TIDAL it took a bit longer, 3 or 4 Transition, but it always ends up with described issues
do you have any news on this topic? I can add that the issue still existent and even more. It doesn‘t restriktive to Streaming Services and Display off. Any Playback in the djay App starts to stutter, if the Djay App is in the backgroud. Now it‘s not possible to use the App together with Apps Like Remixlive or Launchpad because of this issue, as it stutters in a Strange Loop, once you switch to another app and stays for about a 1 Minute using other App. Is this something related to RAM, IpadIos Upgrade or ist is it any djay Setting?
Hi @maxim_varvashenia, thanks for the additional info. We believe this is related to using Neural Mix while having djay run in the background. The team is still working on a solution. So in the meantime, I recommend that you either don’t use NM or don’t run djay in the background. I hope that helps!
Also letting you know that I am still having the same issue. I appreciate the update and that the team is working on a solution but not using features that we paid for should not be a workaround.
Not blaming you at all but this has been ongoing for a while. I brought this up in December of last year! Can we prioritize this?
