Automix issues with channel faders half way with ext mixer
  • Device model - macbook air M1 11
  • Version of operating system macOS 15.2):
  • Version of djay 5.6.7
  • Hardware/controllers used ddj-sb2 pioneer
  • Hardware firmware version - unsure
  • when having my channel faders half way down (end of the night) and switching to automix the faders woudl virtually jump up to 100%, i was in external mixer mode with a usb audio interface connected.
C) EXPECTED RESULTS:
D) ACTUAL RESULTS:
Hi @Stephen_Anning, welcome to the Community! This is expected behaviour when using Automix. If you need to reduce the output volume when using Automix, I recommend you do this with the master volume or Gain/Trim controls instead of the channel faders. I hope that helps!
