In the Ipad version, I’m finding that the ability to use the automix is really limited by the fact that you can only point it to pre-existing playlists, not to a BPM range. Unless you have pre-existing BPM ranged playlists, you’re getting a random mix of BPMs. It’s possible (but tedious) to create these lists in other apps but then the BPM is calculated by that app and may be different from djay!
I bought the Mac version as well to see how this is handled and it’s a little bit better. but what you really want is a way to add a BPM range to the automix cue, and preferably harmonic filtering as well! This would take the app into the truly awesome range in my opinion and it seems like a smallish change. Thanks, Paul
