I just upgraded to the new version. But it seems that automix just doesn’t work the way it used to. I load a playlist from Tidal into automix and start it up, and it works. But it won’t let me change up the order of songs or add additional songs. If I wanted to just play a playlist, I could just use Spotify.
So I think the problem might be that I have to use automix from the queue. That being said, is there any way to load an entire playlist into the queue or do you really have to do it one by one.
Also, try as I may, I can’t find anywhere to change the automix settings like the time before cross fading, etc.
Finally, there used to be a way to advance to the next track by pushing an automix button. Has that feature been removed?
Hi @Rythmrogue,
Welcome to our new Community and thanks for sharing your question here.
So I can help you out with this, could you tell me which version of djay and which OS you’re currently using?
