- Device model : iPad before M1
- Version of operating system : IOS : 16.7.10
- Version of djay : 5.2.4
- Hardware/controllers used : Not controller related
Hello,
Automix works great on my Mac, but I have issues on my iPad, when Automix is sourced with the Main Queue :
With Automix on the Mac, it is possible to start the Automix wherever in the queue. Starting from a song in the queue, Automix will then continue to the next one which is how it should be. On the iPad, when selecting a song in the Queue, Djay will propose to put this one on top of the queue, or just play this one, but there is no way to just start Automix from there, while this is the standard behaviour on Djay for Mac. This is rather annoying. After playing this song, it will continue with the top of the queue. Not continue from where this song was, as Djay is doing on the Mac.
Clarification : When Automix is sourced with a Playlist on iPad (not the Main Queue, it works as expected).
Illustration
Automix behaviour on Mac working perfectly as expected
Start situation : Automix queue empty
Then loading a track from the queue on deck 1
We see Djay is already prepping Automix from the track following this one.
When starting Automix, it will correctly continue with the desired song (the song after where I started the queue.
Automix using Queue behaviour on ipad (not consistent with Mac)
Start situation : Just as for the Mac case, I pick a song in the queue (I want to start from there). To make the exemple easier to follow, I take the same as for Mac case.
But then we see Djay is not adapting the Automix Queue, it keeps the queue starting from the very beginning.
When starting Automix, it will then obviously start from the very beginning of the queue, regardless of the song I choose in the queue (you see the song “Intro” coming up instead of Kiss.
Thank you
