Device model: Macbook Pro
Version of operating system: Ventura 13.7.5
Version of djay: 5.3.1
Automix randomly loading songs from previous playlists (video attached)
Also (additional bug/suggestion): Automix should understand to never load songs that have already been played or are already playing (as is the case 7 seconds into video). If there is a special need for this behavior, it should be an option in settings with default setting OFF.
Thanks for the video and details @audiosymmetry. I’ve forwarded this to our engineering team for further review.
Hi @audiosymmetry, engineering has identified the issue and is working on a fix which should be included in an upcoming update (likely 5.3.2). Thanks!
Summary of the issue:
How to reproduce the issue:
This automix problem is difficult to communicate but here goes…
The situation. Ill have a song playing on Deck 1.
Deck 2 is loaded, ready to autoplay next. Songs A, B and C are waiting to be loaded from the automix list of songs i want to play.
The problem. I decide to change the upcoming songs from A, B and C to songs X, Y, and Z.
Ill manually eject the song on Deck 2 so that the next song in line…“X”…will load into Deck 2.
X loads onto Deck 2.
But then, after X finishes playing, instead of Y loading…song B plays!
But I deleted B from the list and replaced it or so I thought.
This has happened several times during a set.
Are others experiencing this?
Here’s a video of what Im experiencing. Please excuse the foul language…
Hi @Shane_Crosby, thanks for the info and video. I’ve merged your new topic with this existing one as I believe they are related. This should be fixed in an upcoming update. Thanks!
Sorry for a bit off-topic reply , Morning/goodday @Slak_Jaw why is there so much difference in Automix between the different platforms?
For example
I really love the UP next and + button on iOS.
Why isn’t it there on Mac OS or Windows?
