Hi. Is there a way play in Automix, but have manual control over when the track changes? I find all the automatic settings (including the ones you can modify) on Automix almost always mis-cue the whole thing. To be clear, I don’t want the computer to do anything except beat-match.
Hi @Chris2pher, welcome to the Community! Instead of Automix, you might want to check out the Crossfader Fusion/FX: https://help.algoriddim.com/hc/en-us/articles/11774180045084-How-do-I-use-Crossfader-Fusion-on-djay-for-iOS
This tool handles the beat matching and automates various transitions, while still allowing you to control when to transition. Check it out and let me know if you have any questions.
Alternatively, if you want to ensure the mixes start and end at specific points, you could add Start and End Points to all of the songs in your Automix playlist. I use this feature myself.
Thank you very much for your help.
You’re welcome @Chris2pher. Happy to help!
