FWhat is going on with this app/apple? It seems so unstable at the moment!
In automix if the screen is turned off it can randomly decide not to play the next track (no volume even though the track is playing on the timeline)
If within the app and doing a song search or well anything really it decides to repeat last 3 seconds of the song over and over again until I mix the next song in…that’s if it even decides to play the next track at all.
Turn automix off and it still plays the next song …
To make things worse all of the above doesn’t seem to have an apparent cause sometimes it does sometimes it doesn’t..which is what is so nerve wracking. Anyone else having issues? I use the app probably in its simplest form to do discos but losing confidence in using it very quickly. Vid of a bit of the issue below
iPad Pro (11-inch) (2nd generation)
iOS 18.4.1
Djay version 5.3.1
Tried to add a video but it won’t let me as a new user even though I’ve paid for it and used the app for 9 years
Hi @Vicky_Davies, sorry to hear you’re experiencing this issue. When creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency. Thanks!
Hardware Firmware Version:
I have also changed your user status in the Community to Basic User so you should be able to upload your video now as long as it’s less than 200MB. Thanks!
No problem thank you. I have popped version model info
You’re welcome @Vicky_Davies. Thanks for the device details. Please share your video.
Any help would be appreciated
Hi @Vicky_Davies, thanks for the video.
- Can you please switch to Pro Mode with the Mixer, EQs and Manual FX visible and try to capture another video of the issue? I’d like to check if any of these controls a contributing to the volume issue.
- Are you playing through the iPad built-in speakers or are you connected to some other audio device?
- If you turn Bluetooth Off on your iPad do you still experience the issue?
- Are you running any other applications in the background?
