Automix starts next track too early
have a problem with automix: Djay Pro starts nex track much too early, allthough i have set the fading time to 6 seconds. Please take a look at the screenshot (german language).
I thank for your help!
Hartmut
Thanks, but what i describe is exactly possible at the iphone version. Andy further advice? Kind regards Hartmut
hey, i think the fade time is 6 seconds so thats how long the transition will take, Djay will decide where in the tracks the mix will be so you may want to try, start point and end point, and check the “use start and end point where available” box
