On multiple occasions, I have seen AutoMix transition from one track to another with a VERY long time remaining in the source track. (I’ve seen transitions start with as much as two minutes remaining on the outgoing track)
Is there a setting to force AutoMix not to transition unless this song has less than 60 seconds left, for example?
Hey e,
Are you using djay Ai?
Looks like you can set what you’re looking for in Automix settings.
I think setting you’re End Cue Point would be easier.
Hey @sooteee, If what you described occurs, then this should be reported as a bug with Automix. However, I’ve tried to reproduce the issue you’ve described, but wasn’t able to on our devices here.
If possible, could you please share the following:
Screenshots of your Automix settings when this occurs.
What playlist you’re using, if it’s available on TIDAL?
What device, OS version, and djay version did you experience the issue on?
Thanks for the additional information. Yes, whenever you get to it a video would be great.
To post videos on the Community, you’d need to link from an outside hosting source, like YouTube as an example. It’s not possible to upload videos within posts themselves.
Alternatively, you could also drop a video here, and I’ll be able to access the video that way to take a closer look. Thanks again for reporting this and helping to troubleshoot the issue!
Thanks for sharing those so quickly! I can see right away what’s most likely causing the issue - If you have the Automix Start/End point settings set to Automatic, then Automix uses the automatically set transition areas of the song to transition, as shown here (from your video):
If automatic is set as the start point, what exactly is the action taken by the software? Will it attempt to start on a cue point if one is set? What if there is no cue point set? ( DJAYPro AI on iPad Air )
