When mixing Rock Music, it is my preference to lower the HARMONICS.
Djay will override my HARMONICS when Neural Mix is used.
When Automix Transitions is set to Automatic,
My favorite Automix was the original (pre 5.3) neural mix map, I think it’s gone with the update. Selecting Neural Mix Fade is close but it’s not the same. I can do something similar with the neural crossfaders, but then it wouldn’t be automixing.
