Does automix play the songs on your spotify playlist in order or does it shuffle automatically. I have a playlist in the order I want it to go for the party but when I do automix it bounces around and doesn’t go in the order of the playlist.
thank you for your mail.
You can use the Queue or select a Playlist which you like as media source in the Automix settings
