Is it possible to pre-set a playlist in Djay Pro for iPad and let it play in autoplay? I.E. if I have defined the next 5 songs I would like to let it autoplay, before I go back to work
I have the same question. I add songs to the queue, automix is selected as on, and it just ends at the end of the playing track.
yes this is possible via the Queue function.
You can swipe a track in the library to the right in order to add it to the cue.
After activating the Automix these tracks will be played with the according Automix settings.
I added songs to the cue but they won’t automatically load to a free deck and how do I set the songs to automatically transition to a new one?
Yes the same problem happens to me.
Hi, make sure you are using Automix and the adding songs to the Automix queue.
I was having the same problem, but it turns out I was adding things to the standard queue and the Automix player does not look at the standard queue. The automix player only looks at the automix queue.
Hi, make sure you are adding your songs to the automix queue and not just the standard. I was having the same problem. Right clicking on songs and selecting add to queue does not add to the Automix queue. You will manually have to drag and drop songs into the Automix queue.
Wizz, I was a bit lost too. After you drag your things to the “QUEUE” on the right, click the red arrow at the bottom and click “START AUTOMIX”
Hey folks,
does anybody know if the automix session and also the automix queue does have some hotkeys to go through? so how do I get some tracks into the automix queue and how can I let Djaypro play those selected tracks (without using a mouse/trackpad)?
and how will I return back to the standard decks and the queues for the decks I am using?
Thank you in advance!
