Installed djay Pro for Windows and added a bunch of songs to the queue, but it seems it doesn’t load a new song in a deck automatically. I’ve looked through the manual but can’t seem to get it work. What am I overlooking?
Thanx in advance.
Finally found it. Play button at the bottom of the screen.
Hi Dick Pluim,
can you see which tracks the Automix is loading instead?
Are you working with an active Automix?
Is the Queue still getting edited after a transition?
