I have just a suggestion, what if, the analyzing would run in the background?
Now if you run analyze 200-300-400 songs, you can NOT use djay Pro, and play song until not finished the analyzing.
(iOS)
(iOS)
Background analysis runs well on my M1 MacBook. You need to post the software version and equipment you use or we won’t be able to help.
Thanks for the suggestion @DJ-Z. I’m assuming you are talking about iOS? I have forwarded this to the dev team for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
Hi There
iPad Pro
Reloop mixtour Pro
DJay pro ai updated
Tidal and Apple music streaming
When I start to Analyse tracks in a play list the Analysing window pops up but then I can’t keep mixing. It does not seem to keep the process going in the background when the window is closed.
In MacOS on my macbook pro I can “minimise” the window to the dock and the process keeps going while I can keep playing.
Is that a shortcoming in iOS or is there a way to do that.
Cheers
B
Hi @BenC, I’ve merged your new topic with this existing one. This is currently a limitation of iOS.
@Slak_Jaw, yes I noted that on iPad
