Bar counter for Cue Points
How about a bar counter that shows how many Bars remain until the next Cue Point of a track.
This would allow you to easily see when to start the next track, so you can time the mix perfectly.
I like to use cue points to mark the intro of a track to mix in, and the outro of a track to mix out so I can cut to the next track at the perfect moment.
This would save people from having to know the structure of a track off by heart, and would allow them to use visual cues instead.
Thanks for your time.
thank you very much for contacting us!
I definitely will hand this over to our developers as an Idea for a new feature!Thanks for your support.
Best regards,
Alex
Just spotted that the CDJ-2000 has this exact feature,
as demonstrated in this video at 7:47…
https://www.youtube.com/watch?v=TaQHV…
Please add this to djay, it would really help! :slight_smile:
Thanks Very much Alex! I have another suggestion here which is crucial for people that use DJ controllers if you can have a look:
http://gsfn.us/t/4sztl
