Device model M1 MacBook Air :
Version of operating system Sonama 14.4.1 :
Version of djay 5.1.3 :
Hardware/controllers used Just on laptop, evaluating software :
Summary of the issue:
When viewing the waveform at the start of the track, there are numbered markers that show each bar.
Surely the one at the start of the track/1st downbeat should be labelled “0” rather than “1” ?
At the moment they’re are labelled “-2 -1 1 2” …& miss out 0 altogether.
Image attached
How to reproduce the issue:
Ian_Williams1:
Why? It’s the first bar, hence bar one (1).
spiro
April 16, 2024, 9:25pm
3
That would break with how most other software handle this.
Would be very messy.
This confused me a bit when I would calculate where I would put outro cue points but then I realised when I make the calculation I just need to add 1 to it
system
Closed
April 17, 2025, 1:05pm
6
