The beat matching in Djay is spot on but for alot of my tunes (maybe 20% of them) it sets the yellow beat up for the second beat in the bar not the first so when I use Sync it syncs to this one and it not right, resulting in bad mixes. Would love to be able to manually override this when software gets it wrong.
Hi Conor,
Please try Chewey’s suggestion.
You can adjust the down beat yellow bar in the wave form screen. Tap the pencil icon and then set
Yes that worked - brilliant. Thanks.
