I have been using Djay pro 2 since January. I believe it’s time to give some feedback what is a must on the software updates. And I hope this question has been asked before and that we can get some more updates coming (only one small update in February with fixes…).
Bar number count (make it visible!)
I don’t know how dj:s quickly go through a whole new long playlist to set que pionts fast etc, but it would be really useful if there would be the option to see the bar number so I don’t have to count 8-, 16-, 32- Bars etc… At least it would save a lot of time if an option to make them visible could be added. -
Possibility to have 8 que points as default? (Always have to set it again)
I have a controller and can use up to 8 que points on my controller. When opening djay pro 2 the default que points are set to 4 and I always have to manually change on all the decks from 4 to 8 que points. Can this please be an option to make in the settings so I don’t always have to manually change the que points from 4 to 8? -
Single color waveforms?
The color is all nice and so on but sometimes it just have a lot of necessary and confusing rainbow colors. One blue/purple:ish color option would be fantastic!
-Possibility to Zoom out the waveforms more
I hate it when you cannot zoom out the waveforms more. When playing with 4 decks the waveforms are zoomed out a lot more and I wish they could be the same for when you play with 2 decks.
Looking forward to the comments and the implementations!
