I have been really enjoying the Neural Mix EQ, and recently set up a midi controller to help control all of the functions. The only issue is that when you select the 4 channel option, the gui doesn’t show the bass EQ. Since I am using relative encoders (with infinite range), I have to use the gui to check where the EQ is, and this is impossible to know without the bass knob. Am I missing a setting somewhere? Under “Sound” in the settings I see the option to change the type of Neural Mix EQ, but both options have 3 components, not 4.
A post was merged into an existing topic: Add 4 channel Neural Mix EQ (Melody - Harmonics - Bass - Drums)
Merged with existing topic: Add 4 channel Neural Mix EQ (Melody - Harmonics - Bass - Drums)
