Hi @Rob_Grimes,
Can you please try to capture a video of this issue, upload it to your Dropbox/Google Drive, enable the necessary file sharing permissions, then share a link to the video here? This will really help to clarify what you’re describing. Thanks!
Thanks for the video @Rob_Grimes. I’ve forwarded this to the engineering team to see if they can reproduce the issue and offer any suggestions. Thanks again!
Hi @Rob_Grimes, I just wanted to give you a quick update. The engineering team was able to reproduce this issue and is investigating it further. We believe it has something to do with using the 3 stem model by default for the FX while having the 4 stems separation active. In the meantime, you could try changing from the 4 stems separation to the 3 stems separation. This should ensure that the bass is included in the harmonics when apply FX.
Thanks for the follow up. I’ll look into that workaround for the time being but since I have the 4 stem buttons on my DDJ REV5 mapped and do have a couple of mixes that leverage keeping bass+drums going (like Blue Monday…) I might just have to remember to manually switch off bass if I’m activating melodic echo out.
