I cleared a beat grid as it was not accurate (couldn’t get the downbeat set right), how do I get I d anew Analysis? Could not find in the in beat grade section of manual (so wish I was it u to date).
Hi @N_C, see below for how to access the Beat Grid menu on iOS. Also, you could try to re-analyze the playlist containing the song in question.
You can’y analyse a single track? Going via a playlist is the only way?
Hi @N_C, to force re-analysis of specific songs please follow the procedure below for the songs that you are having issues with.
