Hi Team,
I hope you’re well.
I was wondering if it would be possible to implement a feature that allows users to highlight or bold specific bars on the grid at regular intervals, such as every 4th or 8th bar. For instance, it would be very useful if bar numbered 5, 9, and 13 (in a 4-bar or 8-bar loop) could be automatically emphasised in some way—perhaps through bold numbering, a different colour, or another form of visual cue. This would help with quickly identifying key(cue) positions within the timeline during the mix process.
Would it be feasible to add this functionality, or is there a workaround that could achieve a similar result?
Thanks for considering this, and I look forward to hearing your thoughts.
Best regards,
Mista Cee
