Beat jump on the Hercules Mix ultra
  • Device model (Samsung S24 ultra):
  • Version of operating system (Android 15):
  • Version of djay (e.g. 5.3.1):
  • Hardware/controllers used (Hercules mix ultra):
Is there a way to configure beat jump to be one of the shortcut keys for the Hercules mix ultra instead of say bounce loop or slicer? Using it with my Samsung S24 and am unable to find the option to remap anything.
Thanks in advance!
Hi @angelodeath, welcome to the Community! Unfortunately, we do not currently support custom MIDI mapping on Android devices.
So there is currently no way to use beat jump on the Hercules mix ultra?
Yes, that is correct @angelodeath. You will need to use the onscreen controls on your Android device.
Is there any timeline for implementing custon midi mapping on Android?
Hi @angelodeath, we do not have a timeline for adding this functionality to Android.
