Something strange has happened recently but first I’ll let you know the equitement being used -
Ipad with your software and Pioneer DJ400 controller.
When pressing sync this not sync’s the correct BPM but not the beat which it previously done. Which I can work around if need be. But the issue also is if I try to loop it jumps out of beat.
I have tried unsyncing before selecting the loop and this hasn’t worked either.
Also for some reason now I have numbers on the waveform which I hadn’t previously so unsure if this has something to do with it.
Hi @Stick, When creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency.
Hardware Firmware Version:
Since this sounds repeatable, can you please capture and share a short screen recording of the issue to help clarify what’s happening? Thanks!
