When you sync with 1 beat it’ll line up the nearest beat on track A with the nearest beat on track B
When you sync with 4 beats it’ll line up the nearest bar (yellow line) on track A with the nearest bar on track B
If you properly maintain your beat grids the latter is probably more convenient
I tend to use 1 beat because I’ll generally DJ by ear anyway so it’s just a case of a slight adjustment for my poor timing rather than actually trying to sync things.
Both feel quite valid options to me depending on how you DJ and I wouldn’t say my approach is necessarily superior, just fits how I work better.
While I get the difference technically, I don’t get which is likely to be more reliable. It would instinctively seem 1 beat, yes? But does that come with any cons? If not, what is the point of having a choice?
Hi @N_C, there is no difference in the reliability of the sync. This simply changes where the sync snaps to; on any beat or at the start of each bar (every 4 beats). If you have it set to 1 beat then the 2 tracks can sync on any beat of the 4 beats within the bar. So on beat 1, beat 2, beat 3 or beat 4. If you have it set to 4 beats then the tracks will only sync on the start of each bar which is always beat 1.
If you don’t know what I’m talking about regarding beats and bars, have a look at this video that explains counting of beats and bars for DJing.
