Beatjump for RP8000mk2
Hi!
Just started to fiddle with djay.
I got a Reloop RMX90 2x RP8000mk2.
I noticed that the beatjump is not programmed on the RP8000mk2 (Atleast from what I have found).
Any idea how I can add the function, was looking at the midi mapping but didn’t get any wiser.
Thanks in advance
Hi @djfredhaze, here’s a guide to MIDI Mapping on Windows. I don’t have your specific hardware, but it should be pretty straightforward to add this functionality yourself via MIDI learn in djay Pro.
Thanks, will test it out!
I’m not at my computer right now, but I believe the MIDI commands you’re looking for will be called something like Skip Forward and Skip Backward.
That was my next question, haha.
Got it working, thank for fast replies! :slight_smile:
You’re welcome @djfredhaze
