The beat skipping (for example, 4 beats backwards) gets out of sync a few ms everytime i pressed
Did you install the 5.0.1 update? I think I saw something in the release notes on this…
Yes, 5.0.1. you can reproduce it, setting a shortcut for backwards like 4beats, sync two stable bpm tracks and it will get out of sync a few ms every time you jump.
It is noticeable if you jump to negative bars (before track beggining).
Yup. You are right. Fast forwarding can also trigger it…
@edukees and @Mister_Tuur thanks for sharing this. I have reported this to the engineering team to see if they can reproduce the issue and offer any solutions.
Hello again @edukees and @Mister_Tuur, the team was able to reproduce this and are working on a fix. Thanks!
Same here on iPad. When I’m mixing two tracks with SYNC on, and beat jump one of the tracks, the SYNC just turns off.
I just tried 5.0.2 and only keeps on sync if “sync” is active, the beat jump problem its still there.
Still there in 5.0.3.
Beat jump no longer disables sync which is good.
Beat jump works flawlessly during the duration of the song. However, I did run into @edukees issue where beat jump gets out of sync in the negative bars, and the SYNC really has to kick in.
Here is a YouTube video of me experimenting around:
First I beat jump around in the second deck with no issues. However when I beat jump into the negative bars, there is a noticeable offset (see beat grid lines).
Hello everyone,
I’ve been told that this will be fixed in the next release. Thanks again for sharing all this information.
