I’m testing DjAy at the moment in DVS Mode with Serato Vinyl. The response of the Software compared to the movement of the pitch fader is extrem lagging. For Information: All songs are correctly analysed.
There are two problems that I have several times:
If you beatmatch by ear and this sounds fine over 30 sec or more, also the Waveforms are showed in perfect match, the BPM of both Songs are different. For example: 128.3 for Deck 1 and 129.1 for Deck 2. This is really confusing.
If you want to beatmatch visually it’s impossible. I want to match the bpm of both decks manually and you move the pitch fader of the Turntable then you have this extrem lag and DJay jump extrem between different BPM numbers, sometimes up to 0.5 steps.
If you want to change from 126.7 to 127 straigth is nearly impossible. If you slightly move the pitch fader at the Turntable, nothing happen in then it start to jump the bpm number up to 127.5 then you go back nothing happens, then again you are at 126.3. So slight moves at the Turntable pitch faders has no reaction in the software.
My Turntables, System and Needles works fine with Traktor DVS, Serato DVS and Rekordbox DVS. Only in DJay I recognize this phenomen. Do anyone else recognize this?
In this way is nearly unusable in DVS mode, because it takes everytime so long to beatmatch the songs.
