There ate a few songs I want to put into a play list but some of them have curse words in them and I want to beep them out. Can this be done in Djay?
This functionality is available if you’re using the Numark Mixdeck Quad with the djay app - it’s labelled “Blip/Reverse”. This means the code exists within the app, it’s just a matter of mapping it to a controller or finding space on the screen to trigger that feature.
Hi Kim,
Which djay version do you have - iPad, iPhone or Mac?
djay for Mac:
http://community.algoriddim.com/algor…
djay for iPad/iPhone:
You could use one of the Instant FX or Bounce loop (same as for Mac).
