Can I connect iPad mini 5 to my mixer (Behringer ddm 4000?) I have djay pro ai latest version. I also have dvs cotrol vinyl.
Can I use Technics sl1210 mk7 turntables for dvs?
Unfortunately, the Behringer DDM4000 is not on this list.
However, if it is USB Class Compliant (ie doesn’t require drivers to be installed), then the audio interface should work and you should be able to able to MIDI map the controls yourself. I recommend you contact Behringer to determine if the DDM4000 is class compliant.
