I am using DJ Pro AI with my Mac Air (Version: macOS Big Sur version 11.2.3
CPU: 1.6 GHz Dual-Core Intel Core i5
RAM: 8 GB)
I would like to have all 4 channels on the software option connected via USB to the Behringer Pro Mixer VMX1000USB 5-channel DJ Mixer.
I appears that only one channel is connected to the mixer.
Do I need to to download a particular driver for the mixer ? (It has recognized it as as such and is plug and play compliant).
On the other hand I was able to use two channels in the mixer by using and external audio interface with 4 rca outputs. It is rather expensive to get one with 8 rca outputs.
Can any one recommend any viable less expensive options ?
Many thanks in advance.
Dede
