Which DJ controllers work best with DJay Pro using my Mac? All the ones I look at seemed to be for Serato or DJuced.
Well, what does “best” mean? First of all, you should check the Algoriddim website to see which controllers are generally compatible. Then it’s a matter of personal taste and, of course, your wallet. For me, it’s also about a good compromise between compactness and functionality, and from that point of view I think the Inpulse 500 and of course the Mixtour Pro are a good choice.
Hi @Isaiah_Sanabria, welcome to the Community! Please refer to the link below for all hardware that is currently supported with djay on macOS. Note there are some features at the bottom of the list that are not currently supported on specific hardware. As for which is the “best”, this really comes down to personal preference. My personal favorites are the Denon DJ Prime 4, Reloop Mixon 8 Pro and the Reloop Mixtour Pro. I hope that helps!
