best set up to record a dj podcast whcih uses a mic as well
hi
there might be a simple answer, but i cant quite work out the best set up. I would like to record my mixes, but with live talk over the top in places, like a radio show. i
i have
iPad 4
pioneer ddj-wego
USB Audio technica mic
Djay
audiobus on ipad
garageband on ipad
Thanks!!
Hi Enfield,
djay for iPad supports Audiobus, so together with this app, you can use a mic and record the entire mix.
