Dear Sir/Madam,
Will you be looking to give longer auto mix durations as at the moment it can only go up to 30 seconds. Some mixes I do can last for 2 minutes. Also have you thought about having a beat/bar option as well as seconds. Most electronic dance tracks would auto mix better if the auto mix started a certain amount of bars from the end rather than just a set time.
Kind regards
Ren
