Better Playlist Management in djay Pro
Suggestions for better Playlist Management in djay Pro.
INTERFACE:
  1. Playlist Checkboxes - In Spotify, they have a checkbox next to each playlist so we can see which playlists contain the selected track. The checkbox also lets us add/delete a single track from multiple playlists.
  2. Quick Playlist Toolbar - a toolbar that can be customized with playlists to be used during a gig
COMMANDS:
  1. Export regular playlists to Apple Music
  2. Import/Export playlists to .m3u files
  3. Add to Target Playlist - a command we can map to a keystroke and quickly add/delete tracks to a playlist we are working on.
SMART PLAYLIST OPTIONS:
  1. Randomly Ordered Playlist - every time it’s opened the tracks are in a different order
SYSTEM PLAYLISTS (like the built-in ā€˜Music’ and ā€˜Recently Added’ playlists)
  1. Trash Playlist - a place to put tracks to be deleted (and actually delete them)
  2. Target Playlist - a playlist to put tracks, preferably with a shortcut command to add/delete the track from the target playlist. Similar to the Prep crate in Serato. Please note, this should be separate from the Queue which can be in use during a performance.
Thanks for the suggestions @Michael_Wisniewski! Great ideas. I have forwarded this to the dev team for consideration.
Absolutely support those suggestions. Browser need major renovation.
I would add option to export playlists in XML format with ALL track data.
It greatly helps to work with library with AI.
Do I correctly remember that djay is Pro AI? :blush:
Now I’m dragging files to Traktor to export library in NML (subset of XML) format
Thanks for the additional feedback @Mikhail_Kapyrin. I’ve shared this with the devs.
Another Command suggestion:
  • Send Loaded Track to playlist - a track loaded onto a Deck can be added to a playlist.
Added to djay Pro 5.2.6 (macOS, Windows)
Drag and drop tracks from decks onto the media library or onto other decks: drag the artwork in the track display (macOS, Windows)
Just scrap it and start again.
Would love to see a View dedicated to building playlists. Something dedicated like the Automix View, but where we can quickly add tracks to playlists (could also be tied to Automix for listening). Would also have a button to quickly add tracks to a working/target playlist.
Ideally this would be a dedicated view on iOS so we can walk/hike/jog while creating playlists.
Thanks for the additional input @Michael_Wisniewski
I’m new to this app but the default and not removable ā€œMusicā€ playlist should NOT exist!
I deleted the melodies inside and automatically deleted the content of others playlists! :sob:
Serato 4 (Beta) is adding some cool playlist management features. Would love to see these features in djay Pro. Here’s a short list:
Playlist Sort - similar to sorting tracks
Playlist Colors - color playlists as another level of organization
Show In Playlists - select a track and see what playlists it is in
Track Rating Emojis - cool way to organize (but not sure how you would sort or search this)
Queue Window Toggle (aka in Serato as Prepare Window)
Would love an on/off toggle for the queue - and have it fill the entire library pane. During open-format gigs, I throw on-the-fly ideas into the queue, but at a certain point, I just want to mix what is in the queue and get rid of the playlist and track windows. (in a similar vein, would be great to have a toggle to turn the playlist, tracks and automix windows on/off to get them out of the way).
Thanks for sharing @Michael_Wisniewski. Looks like some new Suggestion topics have already surfaced.
Thanks @Michael_Wisniewski & @Slak_Jaw,
I must have missed these suggestions for better playlist management earlier, but I’ve now voted for it.
Regarding the Serato update.. It seems like they did a great job. It looks very slick to me.
The ā€œFavoritesā€ for playlist is something I’ve also been suggesting for a long time, as you can see here:
So: yes I am totally for it.
I love how many updates that actually matter have come to pass since Ive been using DJAY (not even a year. )The serato crates now has some fantastic feature I’m hoping DJay would also add. Its probably the only thing as this point for me that I like about serato in general.
Hi @Jason_Jaso, thanks for the suggestion. Can you please be more specific though? Thanks!
EDIT: I’ve merged your topic with this existing one as I believe they are related. In particular, please refer to the other linked topics above for some specific suggestions related to the latest Serato update:
Yes watching that video Michael posted would be the best way. Thank you.
Excellent! You’re welcome @Jason_Jaso
Yes!! @Michael_Wisniewski you’ve hit the nail on the head with that request :sign_of_the_horns:
I also came from Traktor and absolutely loved the Favorite‑Bar functionality—it was a game‑changer for quick access.
Seeing Serato release version 4.0 with more flexible playlist tools has me excited too. But honestly, I’ve fallen in love with djay Pro and plan to keep using it—it’s truly one of my favorite DJ platforms.
That said, there’s definitely room for enhancement in djay’s playlist tools:
  • The ability to create a Favorites playlist, similar to Traktor’s Favorite Bar—or even better, a toolbar you can customize live on stage.
  • A searchable Playlist view. I see this being added in Serato 4.0 and I’ve thougth about this for awhile now. That would be SUPER helpful during open format events/club events.
  • I’m still holding out hope that future updates bring hardware waveform support for mixers like the Pioneer S11, Rane Seventy‑Two, and controllers like the Rev 7 and others. That would elevate live performance even more.
Overall, I’m really impressed with what djay Pro has achieved so far. I stick with it daily and trust the developers are listening. Please keep pushing these feature refinements—we users really appreciate your dedication. Looking forward to what’s next!
Another Playlist Suggestion:
Folder-Linked Playlist
Special playlist linked to a folder in the OS. Similar to My Files, but the folder-linked playlist lives in My Collection.
Thanks for the additional input @Michael_Wisniewski!
