bigger buttons,CDJ mode, and keylock "lock"
hi, could algoriddim please include the following, in a future update please?
which i think would make this already brilliant app completely flawless!
thanks!
1> please make “autosync” work automaticly when not in automix mode
2> introduce CDJ Mode
3> please make pitch bend + & - buttons a little bigger and move the (slightly) away from the sync button
4> please make the key lock button a little bigger, & move it away from the deck & the pitch control slider, and make it so it can be “always on”
I’ll second that :slight_smile: ! Great app none the less.
please allow cdj 400 automapping… it seems doesnt work with the jog well …
also allow djay to use just one cdj and switch between them
thank you
