I saw that Djay Pro v.3.8 came with:
Improved slip mode and enabled blinking of SLIP buttons on MIDI controllers while slipping
I have Denon Prime 6000 players. Is it possible to activate the blinking on the SLIP button and how do you activate it? Can’t find it in the MIDI programming menus. Thanks!
- I use a MacBook M1 Pro as a dedicated gig laptop with MacOS 13.7.4
I don’t want to update it to 26.4.1 to keep it light and only for DJ’n.
- Djay Pro 5.6.2
- Yes, I started with the build-in MIDI mapping for LC6000, but made a Custom Edit. It works really well and I couldn’t be happier. I combine it with a Numark Scratch also with a Custom Edit.
- Yes. But since it’s the LC version it doesn’t have a new Firmware.
Sorry for the late reply. I missed clicking “send“
Thanks for the follow up and information @Simon_Matsuyama. Can you please test with the (built-in) MIDI mapping to see if the blinking Slip Button works?
Hi again @Simon_Matsuyama, were you able to test the (built-in) MIDI mapping?
Hello! It’s been 2 weeks since my last reply. I’m going to consider this topic completed for now so I can focus on others. However, please feel free to respond and we can definitely revisit this. Thanks!
