Bluetooth Latency
Why is there a latency problem while using Bluetooth. Other apps don’t have this problem. I am now regretting paying for this app which was fine for about a week of usage before going pro. I cannot plug in because I use an Iphone 11 which has no audio jack outlet
Note: This conversation was created from a reply on: Cue point issue in Djay Pro.
Hi Mike,
A bit off Bluetooth latency is unfortunately expected. Can you share which Apps don’t have the latency?
Regarding the Headphone Jack, we always recommend using the Lightning to Headphone Jack adapter in order to have no latency.
Cheers
