Bluetooth Not Holding Connection with IPhone 15/Ipad
*Iphone 15 and IPad Mini 2024 :
  • 18.2.1 and 18.3 Beta:
  • Version of djay : 5.2.8
  • Hercules DJ Control Mix
I have a problem with my DJ Control Mix and the Bluetooth connection on my iPhone 15 Pro Max and my 2024 iPad Mini. The Bluetooth connection only lasts for a few seconds and then disconnects.
I have tried removing and re-adding the DJ Control Mix in the Djay app, but that hasnt provided a lasting solution either.
Thanks in advance
How to reproduce the issue:
Hi @Diii_Nooo, welcome to the community! Please note that Beta iOS versions are not supported by djay. I highly recommend that you start by switching to the latest officially supported iOS then try the following:
  1. Close djay and follow the procedure below to perform a Forced Restart of your iOS device:
    a. iPhone: Force restart iPhone - Apple Support (CA)
    b. iPad: Force restart iPad - Apple Support
  2. After rebooting, please make sure no other Bluetooth devices like AirPods, speakers or wireless keyboards are trying to connect to your iPhone or iPad when using the DJ Control Mix.
  3. I highly recommend that you disable Bluetooth on your other iOS device that you don’t currently want to use with the DJ Control Mix so that both devices are not trying to connect at the same time. This is most likely what is happening - it disconnects from one device because it accidentally connects to your other iOS device. I hope that helps!
