Ok so i would like to use djay2 with an iPad and a pioneer ddj wego4, but instead of a wired output to speakers, i would like to use a Bluetooth speaker or Wi-Fi speaker.
This works with djay2 for android…but only with a Bluetooth speaker, which is fine. I have not found a way to use a Wi-Fi speaker yet. I know the possibility is there as i can stream direct from Spotify to my Wi-Fi speaker so am sure this is just a software issue that could be addressed?
Djay2 for android does not work well either so i give up with it.
Now…back to djay2 for iPad, which is a whole lot better in terms of stability and features, however…i can’t use a Bluetooth speaker at all. I can use a Bluetooth speaker to play music from my iPad on its own, but as soon as djay2 is loaded, the sound will not come through th speaker.
Can this be fixed?
