Using a Pixel 7.
Device is paired but not connecting
Hi @Kiz,
Thanks for sharing your post with the community.
So that I can better assist you could you please answer the following questions:
- Which OS version is running on your device?
- Which djay version are you using?
- Please explain step-by-step the issue you are experiencing, what you expect to happen, and what actually happens.
Thanks so much!
