Just noticed the knobs, slides, switches, as well as the algoriddim logo at the top / NEURALMIX logo in the middle look fuzzy even in full screen mode. Pro subscription active, thus unrelated to any limitations of the free version.
Hi @Alex_N7,
Thanks for reporting this to us.
Could you please tell us:
- What macOS version do you have installed on your iMac?
- What djay version are you currently using?
- Are you only using the iMac screen or do you have other monitors connected?
Hope to hear from you again. I’m sure we’ll find a solution to this.
Cheers, G
They also look fuzzy on my iMac (M1 2021). It’s not really bad but the text is noticeable more crisp than the buttons/sliders. It looks as if there is a slight blur applied to the buttons.
macOS Monterey version 12.1
(24-inch, M1, 2021)
djay version 3.1.9
using imac screen (full-screen mode)
Do Algoriddim staff even read this? No response whatsoever.
Hi @Alex_N7, we’re investigating this. Could you please give us the additional information about your iMac?
Thanks in advance.
Could you please share a screenshot of your entire screen so we can check how it looks?
Thanks in advance.
Cheers, G
I hope you can make it out in this screenshot but basically every element that is not text (buttons and other graphics) is a bit fuzzy. Its very noticeable next to the crisp text.
hmm ok so that PNG was processed by this forum in a jpeg and with the artifacts that it made by compressing the image you can’t really tell the difference anymore
