BPM auto sync after mix
I’m new on Djay Pro and in the automix MODE the next sound gets the first sound BPM but after mix do not come back to original one. Example current sound 84BPM and next is 92BPM… mixing starts at 84BPM but do not recover the 92BPM… Anyone can help if it is a config issue from my side?
Are you using a Mac?
try using these settings
Use morph
If you’re talking about iOS, this feature only works for Djay Pro 2 via Mac.
Hi Sergio,
you can keep a specific BPM level by activating the Auto Sync for Automix.
We hear you loud and clear, rest assured that we care about all our users across all platforms.
While we never make commitments about when we release certain features on certain platforms we do have a strong roadmap for all of our applications.
Anybody knows when the “morph” feature will run on a Win10 System?
would be great =)
