My track’s BPM grid was completely fine up until about a week ago. Now almost every song I play has the wrong BPM analysis (its either a beat different or worse still, only half a second off). When the BPM of the song is less than half a beat off it means using the pencil (to edit where the songs BPM starts) doesn’t work. This problem clearly must be fixable as it only started playing up a week ago. I have emailed and not had response, please fix this.
Thanks for your note. To get to the bottom of this we need a few more infos. Could you please let us know the following:
- which version of djay are you using and on which OS? (e.g. djay Pro 2.0.11 on macOS 10.14)
- are you using djay across multiple platforms (e.g. on Mac + iOS)?
- is the issue you are seeing only visible in the beat grid or is the actual BPM value incorrect as well (e.g. 108 BPM displayed for a track that should be 120 BPM)
- can you please send an example song where you observe the above to support@algoriddim.com?
