- Device model : MacBook Pro M1
- Version of operating system : MacOS Tahoe 26.3.1
- Version of djay : 5.6.7
- Hardware/controllers used : Pioneer DJM-450
- Hardware firmware version : 1.08 (Audio Pilote : 4.0.4)
- BPM is not detected when I use my DJM-450 in Auto mode with DJay Pro, any way to fix this by any chance ?
Hi @DJ_KEV1, that one sits on the mixer side rather than in djay. djay doesn’t transmit BPM to the DJM-450, so in AUTO the mixer is working it out on its own from whatever audio arrives at the effect channel you’ve selected — it has no visibility of what djay is showing. I went through the DJM-450 Manual and there are two things worth checking:
Effect channel selector — point it at the channel that’s actually playing (1 or 2), not MIC or AUX.
TRIM — Pioneer’s own troubleshooting for “BPM cannot be measured” points straight at input level. Aim for the channel level meter peaking around 0 dB.
Also, please note that AUTO only measures between 70 and 180 BPM, and some tracks simply won’t read cleanly. When it can’t lock on, the display flashes the last value it found — that’s your cue to tap it in with TAP. I hope that helps!
Thanks Slak, I wanted to test it through the weekend, but unfortunately it didn’t work. I need to tap to get the right BPM
You’re welcome @DJ_KEV1. Sorry to hear that didn’t help much.
Well actually it did this week-end, I don’t know why but the mixer’s utility app opened this time when I connected the mixer.
It didn’t before, and now everything is working perfectly.
Thank you again, now I need to work on how to better midi map my RP 8000mk2.
That’s great to hear @DJ_KEV1. You’re welcome!
