BPM Tap Tempo crashing djay
  • m1 mac mini
  • Sequoia 15.3
  • Version of djay 5.6.2
  • Maschine Jam (native instruments)
    SUMMARY OF ISSUE:
i have x2 actions on the same button (using duplicate mapping)
example
General - select deck 3
deck 3 - BPM TAP
there are times where using the BPM TAP crashes the Djay
this has also occurred in the previous iteration of Djay
Hi @7nz, thanks for the details about your setup and the issue - this is very helpful! Since this sounds repeatable, can you please capture and share a short screen recording of the issue to help me communicate this to our engineering team? Can you please also share screenshots of these MIDI commands with the Advanced Control Configuration section expanded? Thanks!
ill reproduce the bug on video…
i’ve adjusted the bug report heading to highlight it crashes Djay… and not the Macmini
Thanks @7nz
