You have the 2 fingers feature when playing straight from the Ipad screen, can you bring it back (it used to be there) for controllers? It used to work by simply pressing the shift button and scratching with the jog wheel. Should be an easy one. Thanks!
Thank you for getting in touch. Which controller and djay version are you using?
I use a reloop Mixon 4 and version 3.6.1 of Djay.
