*NOTE: Please use the search function above before posting to avoid creating duplicate topics.
hi there… Whatever you did to improve stems… Its bad… Acapellas are too filtered and instrumentals still have tiny sounds of vocals… I tested this on another phone its the same. Or maybe its my hardware but it worked fine for two years
Which phone are you using?
Furthermore check Settings/Advanced/Neural Mix Quality,
If your device is current, it should read 100%
On my iPad Air 5th Gen it’s 100% as well as my iPad 9th Gen,
My iPad 6th Gen on the other hand is only 60% and the Stems quality isn’t as good
Hi @PRO24DJS , as @maurizio_T has indicated, the quality of the Neural Mix separation depends on the power of your hardware.
Neural Mix™ is a revolutionary technology to deconstruct and mix music in real-time. Instantly isolate beats, instruments, and vocals based on cutting-edge AI. While Neural Mix™ was designed to wor...
Version 5.17 worked fine… Im still confused… Is there a way to roll back to the old version?
There is no way to rollback on iOS. On macOS you can use Time Machine to return to a previous version.
system
Closed
August 7, 2024, 12:31pm
7
