I would have this two wishes for improving prelisten function:
Continous Prelisten:
Using my controller, its a little annoying that you have to press prelisten all time if you step to the next track in browser.
As i would use Djay with 2 ch external mixer i don’t see the way to route prelisten. In Virtual DJ it works very well. Prelisten goes to stopped deck, so i only need to activate Pfl on 2 ch external mixer.
We already have an option in the djay Settings>Sound>PRE-CUEING> called Auto Select. This will automatically select the inactive deck for pre-cueing for you.
To setup your External Mixer, open the djay Settings>Audio Device Setup> and set the Mixer Mode to External. From here you’ll be able to assign the Deck and Pre-Cueing to the available channels on your mixer.
Thanks, but im meaning a situation where you have an external mixer but only 2 channels, or you only have 2 stereo output channel sound cards, or you are going to an event where are no more than 2 channels available.
Since I have 2 stereo channel sound card, I can’t do this.
As I just tested the “auto select” in the sound settings, it only works in internal mode where is a fixed path to the headphone monitor. e.g. Out 3+4.
What I have in mind is a non-fixed path for prelisten.
E.g. You are in external mode and you have 2 stereo channel audio interface - Deck 1 (Ch1+2) and Deck 2 (Ch3+4)
When Deck 1 in the air for the crowd and Deck 2 stopped, prelisten automatically goes on Deck 2 (Ch3+4)
When Deck 2 in the air for the crowd and Deck 1 stopped, prelisten automatically goes on Deck 1 (Ch1+2)
Supposedly the stopped deck isn’t on the air, so you can use the the PFL of your external mixer. So you don’t necessarily need an additional channel.
